I am selling my Tormach PCNC 1100 CNC Mill Package, for $25,000 ( Canadian dollars ). Mint condition, barely used. Save thousands in shipping, taxes and exchange! See pictures for details and list of items included in the package., plus many tools, not listed. Serious inquires only please. Located in Kelowna, British Columbia, Canada.Thank you.
The PCNC 1100 personal CNC mills are Tormach’s best-selling small CNC milling machines and a proven performer for prototyping, short run production, education, and hobby CNC milling.
Thoughtful design and engineering makes the Tormach personal CNC mill an unrivaled combination of performance and affordability in its class, with the precision to do real work and power to cut the toughest materials – stainless, titanium, even pre-hardened tool steel. The PCNC 1100 features:
5140 RPM, 1.5 hp R8 spindle with sensorless vector
Control and exclusive foldback logic
Single-phase 230 Vac
50/60 Hz primary power requirement
1400 lb (Typical system weight with stand)
Optional ATC, (Automatic Tool Changer) Stand, and many other options included.
Polyphase axis motion technology powered by Leadshine
Here is a list of the Tormach options that I have included in this package:
Tormach PCNC 1100 Series III plus the following:
30297 - PCNC 1100 Deluxe Machine Stand w/ Coolant Kit
34437 - Cable Kit for Tormach PCNC Mills
31446 - Lifting Bar
35286 - PathPilot Controller
30616 - Jog Shuttle
30615 - Standard LCD Monitor
31371 - Mini Keyboard
31384 - Cover for Mini Keyboard
31289 - USB Bulkhead Port Assembly
31947 - Basic 3 Piece Indicator Set
32279 - Automatic Tool Changer for PCNC 1100 Series 3
32329 - ATC Pressure Sensor
31706 - PCNC 1100 Power Drawbar
31728 - Power Drawbar Foot Pedal Kit
31991 - Pneumatic Hose Kit for Power Drawbar/ATC
32457 - FRL Filter-Regulator-Lubricator
32580 - Clamp Kit for 5/8" T-Slots (58 Pcs.)
32284 - TTS CNC Operator Set with Tormach Tool Assistant
31829 - TTS ER Collet Holder: ER20
34086 - ER20/ER16 Deluxe TTS Wrench Set
33443 - 4 Flute HSS End Mill Set (5 Pieces) Plus extra
33465 - 2 Flute HSS End Mill Set (5 Pieces) Plus extra
31386 - Machine Oil
31750 - Full Synthetic Coolant
31374 - Automatic Oiler Kit (230V) PCNC 1100
30490 - PCNC 1100 Owner's Kit
32447 - TTS Diamond Drag Engraver Kit
31284 - TTS Touch Tool w/Digital Indicator and Box
32309 - Passive Probe w/ 10mm TTS Mount
31951 - 6" Parallel Set
30286 - Machine Arm
***** (1) Spare Spindle Motor *****
Non Tormach Extras:
High Quality Carbide Endmills
Indexable endmills
Indexable facemills
Off line tool setter
Calipers
And More………………………………….
I also have a CAD / CAM Package available at an additional cost, if interested.
