Need Help! Ball screw
Results 1 to 5 of 5
Thread: Ball screw
    Jan 2004
    SCOTLAND
    Default Ball screw
    Hi all,
    I had my vise over the end of the table when I jogged the Y axis and it the back pillar, now when I jog the table, the ball screw is trying to come out off the machine.
    Is there a circlip or something that holds the ball screw in place ? When jogging in the opposite direction it is fine
    BR
    Gold Member LeeWay's Avatar
    Jun 2004
    Default Re: Ball screw
    Check out the manual.
    There should be an exploded parts view toward the back.
    Lee
    Jun 2005
    A number of ball screws do have a c-clip or metal cap that is pressed in the end that ensures the balls are retained. Each manufacture has their own method. Look at the exact brand the used that is normally stamped on the ballnut and then look up the specs.
    Russ
    Sep 2009
    Call or e-mail Tormach. You had a crash serious enough to visibly affect your machine. You have a situation that is exactly what Tormach had in mind when they set their tech support policy.
    Jan 2004
    SCOTLAND
    Quote Originally Posted by GLCarlson View Post
    Sorry guys I have posted in the wrong forum My machine is a Beaver VM5 CNC milling machine but thanks for all your replies. I dont have a manual, I just dont know where to start, I would probably have to take off the end pulley and belt to the motor and have a look there
    BR
Ball screw
Ball screw
