Don,
Is the pump sitting through the stock hole in the top of the coolant tank? Or did you have to modify anything else to make the pump work? Will the tank capacity hold up to that much coolant flow? Now that youve ran it for a month or so Im curious as to any thoughts you have on “shouldve done” scenarios or if your a happy camper. Thank you Sir!
