That is a blood hard bug to reproduces, It's something in the radius settings with G17 to 19 The HSM guys say not to use R for anything over 90 degrees
Is anyone else having issues with the latest Tormach.cps Fusion 360 post?
The latest post version:
post version 41493
post modified 2017-07-01 154921
Error I am receiving:
Error(/Users/mfahey/Library/Application Support/Autodesk/Autodesk Fusion 360/WT6CL8W2YJPF/W.login/M/D2017012159758881/CAMPosts/tormach-pmf1.cps:1239): TypeError: gFeedModeModal is not a function
Stack dump:
onCircular@/Users/mfahey/Library/Application Support/Autodesk/Autodesk Fusion 360/WT6CL8W2YJPF/W.login/M/D2017012159758881/CAMPosts/tormach-pmf1.cps:1238
Failed while processing onCircular() for record 281.
Error: Failed to invoke function 'onCircular'.
Error: Failed to invoke 'onCircular' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thu Jul 13 18:57:00 2017
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
I found what I believe to be the issue. It appears as though there is a syntax problem with some of the new inverse time code. I made the following changes:
Search post file for: gFeedModeModal(94)
Replace with: gFeedModeModal.format(94)
Saved the post under a new name and add it to my directory and cloud library.
Use this workaround at your own risk. I am not a programmer, nor have I tested the post and post changes for issues which could destroy parts, crash the mill, cause serious bodily harm or death, or bring an end to the universe....
There is an updated post available. It was in the forum yesterday and they are going to post it on the post site soon.
It should be near the top of the forum
Chris
https://forums.autodesk.com/t5/hsm-p...a/td-p/7224183
