I generally find it easier to make more accurate parts the first time around on my Haas over my Tormach especially with being able to measure tool diameter easily. However, the Tormach is plenty accurate and is repeatable and once parts are dialed in you can make great parts. There are so many variables that can throw off the accuracy such as warping from work holding and parts warping after machining and the most accurate machine is not going to fix that.Wow, thank you for your insight.
Regarding your tormach, would you say it can pretty much do what the haas can (tolerances/repeatability) but at a much slower rate?
Glad to hear you are still using your tormach and congratulations on moving up to a 'real' vmc
I bet you are stoked
