Rapid Turn Facing Conversational
Results 1 to 2 of 2
Thread: Rapid Turn Facing Conversational
    Mar 2017
    Default Rapid Turn Facing Conversational
    I just connected my rapid turn, things seem to be going well I have been able to run a number of facing operations to start out. During a facing operation setup with the conversational programming (first part tutorial ) during the run for some reason it runs the x to about the middle of the stock, pauses for some time or slows to a crawl then appears to finish the pass. Is this normal behavior? Some setting to get rid of the pause mid pass?
    Mar 2017
    Default Re: Rapid Turn Facing Conversational
    I have it nailed down to a spindle sensor not working properly at higher speeds. It is exhibiting exactly the same symptoms as keen describes in his video,
