PathPilot PC Shutdown
Results 1 to 3 of 3
Thread: PathPilot PC Shutdown
    Member nitewatchman's Avatar
    Oct 2011
    Birmingham, Alabama
    Default PathPilot PC Shutdown
    As usual disaster has struck when the machine is needed.
    This afternoon the display started getting lines across the screen and acting funny. I decided to shutdown the machine and check connections. When I tried to start the controller back up, it starts to boot and after a couple of seconds the yellow/orange light on the front under the power switch blinks and an alarm chirps. This will continue for a few seconds then the controller shuts down and the cycle of boot/flash/chirp starts again.
    Anyone;
    A) Seen this before?
    B) Have any idea what the flashing light means?
    C) Know what the chirp means?
    Not like anything that I have seen before.
    gary
    Feb 2006
    Default Re: PathPilot PC Shutdown
    This might help: PERFORM THESE STEPS before posting about POST/boot/no video problems! - Systems
    When a PC fails to boot while in POST, it will beep, and/or blink the power LED in a specified (manufacturer-specific) pattern. So, figure out what motherboard you have, not the pattern of beeps or blinks (number of beeps/blinks - some may be short, others long), and do some Googling to find the codes for that specific motherboard. It will usually point to a memory, video card, or other low-level failure.
    Regards,
    Ray L.
    Oct 2011
    Birmingham, Alabama
    Hard Drive is failing, Reseated connectors and slapped it on the butt like birthin' a baby and it now boots. Copied over work files and will replace with a Solid State Drive.
    Thanks for the help.
    gary
