I had trouble with the Z-axis oiler and had to disassemble the fittings and rerouted the oil lines to reestablish flow. Since then I run the Z-axis down and check for oil residue on the exposed channels and often squirt oil manually to assure coverage; cheap insurance. Check the X-axis by running it to each end and inspect for oil residue at the end face, if dry, then investigate. I have found kinked oiler lines at the mount clamp and corrected to solve the problem. The Y-axis requires removal of the bellows at one end to inspect.
From what I see, the manual oiler system relies on a free flow distribution network and each circuit has its own flow rate, based on line flow restrictions, and the path of least resistance gets the lions share of oil. Compound discrepancies in a line will reduce or restrict passage in that circuit.
I have a manual oiler on my 1100 and have assisted the plunger with a little push, every so often, to increase the pressure/flow rate.
