New Rapid Turn Installed
Results 1 to 10 of 10
Thread: New Rapid Turn Installed
    Mar 2013
    U.S.
    Default New Rapid Turn Installed
    Finally completed the installation of my new RT. Instructions were clear and accurate, no problems whatsoever and the machine works great. I'm using the WildHorse switch for the VFD keys but wish there were a switch available for the motor's power cable. It's not difficult to change, just an annoyance.
    Member tmarks11's Avatar
    Jul 2004
    Default Re: New Rapid Turn Installed
    Quote Originally Posted by jttoner View Post
    Plenty of switches available. Just find a two position, three pole rotary switch. I recommend a Kraus-Naimer CA10 A233, but since this switch is seldom operated, and never under load, you could also just use a cheap knockoff.
    At least one other individual here posted previously about adding a switch like this.
    Tim
    Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
    Mar 2013
    U.S.
    Tim,
    Thanks, I'll look into that. Having to fetch a ladder, climb up, then switch cables is beyond Mickey Mouse
    Apr 2011
    What is the wildhorse switch you referred to for the VFD key?
    Terry
    Jul 2004
    Tim,
    He just posted a pic on another thread.
    http://www.cnczone.com/forums/tormac...ml#post2039354
    Tim
    Mar 2013
    U.S.
    Quote Originally Posted by MFchief View Post
    Terry
    It's pricey but worth it. It's a small box into which you insert the Mill key and the RT key. They are switch selected to a cable with a key that goes into the VFD. Makes it unnecessary to open the door to access the VFD. Should be easy enough to make one but I opted to buy it ready made.
  7. #7
    Apr 2011
    When I saw your original post I checked the wild horse website but didn't see anything like that. Is it from the folks who make the wild horse probe, or someone else?
    Terry
  8. #8
    Member kstrauss's Avatar
    Apr 2013
    Try SmartStick Controller for the VFD configuration switcher. I haven't tried it since a 770 uses the same configuration for the spindle and for the Rapidturn.
  9. #9
    Apr 2011
    Thanks, I did look at that one, it is nice, but somewhat pricey for a switch.
    Terry
  10. #10
    Oct 2010
    Sorry about the repost of this. I thought the other one listed above was the Wildhorse one.
    Again, sorry - carry on and go make some chips!
    This one is also available.
    Awall - The Body Armor Dude
    CoolCNCStuff_ on Instagram - CoolCNCStuff.com
