Clearpath Servos for Tormach? - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 31 of 31
Thread: Clearpath Servos for Tormach?
  1. #25
    Dec 2007
    Default Re: Clearpath Servos for Tormach?
    I have clear path servos on some self built machines with very great performance. Very smooth, high accelerations, great for 3d tool paths. I find the ability to fault very useful. I have stepper machines crash and just keep going wrecking havoc on my machine while I was out of the shop. The clear path servos fault very quickly in a crash and the servos can sent a stop signal to your controller to tell all other axis to also stop moving. I probably wont build another machine with steppers again but with that said, I would not invest in them for a Tormach because the added benefits are not worth the cost for me. I use my Tormach for prototype low tolerance parts and squeezing every last second out of the cycle time is not important at all. I have a Haas VMC for that.
  2. #26
    May 2007
    In many parts of the country you can find a used Fadal VMC 15 or similar for the price of a Tormach. You'll get servos, a 10k spindle, and an ATC, and they can run on 220/1PH power. There are also deals out there on Mini Mills but I think parts for Fadals tend to be a bit cheaper.
    The reason I bought an 1100 was I wanted a turnkey machine with affordable support, and I didn't need a lot of speed, power, etc. the clearpath servos look nice but I had built 4 machines already and didn't want another project.
    Now, I do kind of see a use case for tool break detection. Thing is, many of the times I've broken tools, the axes never slowed down. Sometimes the spindle bogs and you snap a tool that way, while smaller tools just break without the spindle audibly changing. At a minimum, a spindle encoder may get catch some of these, while for others you'd need reall tool break detection sensing. I've also thought about using a sensor to monitor vibration to see if you could detect chatter, which could also trigger a fault under the right conditions, but all of these are secondary to the projects I bought the machine for and which it does well enough 🤓
  3. #27
    Dec 2016
    New Zealand
    I have actually changed the Rapid Feed Rate speed on my Tormach to 150inch per min on X/Y and 120 on Z.
    It's so much nicer to use and it even sounds nicer when it Rapid moves.
    There is a lot of development going into 3D printing to make the stepper motors silent. this is all done by the stepper drivers and there is a lot more smart control going into them. Changing step count to a higher number helps reduce noise but can also reduce torque.
  4. #28
    Registered Cromaglious's Avatar
    Jan 2010
    For less than 1/2 the price get some jmc-motor.com iHSS57-36-20 2nm (283ozin) motors. I bought 3 off ebay. If you go direct to jmc-motor.com they'll send you a turner box as well. They work wonderfully. When you get yor machine figured out then you can think about getting clearpaths.
  5. #29
    Mar 2008
    Quote Originally Posted by Cromaglious View Post
    Why would anyone want to do that? The motor that you are recommending has less than *half* of the torque of the Tormach X and Y axis motors. The torque rating of that motor does not even specify the RPM (stalled?) where the torque is rated. Even if we charitably assume that the torque rating is still valid at the 110 inches per minute maximum machining rate of the Tormach, that motor is still significantly below the Tormach supplied X and Y axis motor torques. The Tormach Z axis motor has about 2X the torque of the X and Y axis motors. There is also the rather obvious problem that your example motor is a NEMA 23 while the Tormach axis motors are NEMA 34.
  6. #30
    Jan 2010
    They have a 2HSS86h external driver + NEMA34 86J18156ec-1000 12nm 2phase stepper 1.8 degree (1000 line encoder) closed loop stepper for $248 on ebay. I got 3 integrated closed loop NEMA23's for myself. I gave the JMC-motor.com so you could go look at what they have. They have open loop steppers and drivers, closed loop steppers and drivers, and integrated closed loop steppers. They have been very responsive to my questions. I also saw Leadshine has US distributors and they have pretty much the same thing as well as NEMA17 integrated closed loop steppers. Talk to Michael jmcxx@jmc-motion.com and if you do buy direct from Just Motion Control as to get a tuner box with your order -- no messing with COM parameters on a computer. (jmc-motion.com is their Chinese language website)
    I've been using my 2nm iHSS57-36-20 steppers at 150in/minute at 450G acceleration and that's at 25vdc. They like nominal 36vdc, but are rated to 50vdc. If you want better specifications on performance email Michael and he will answer.
    Cheers Robi
    Robi
  7. #31
    Oct 2010
    Cheers Robi
    Hey Robi,
    So, are you saying that you are using these on your Tormach with PathPilot or in some other application? I think the questions surround how an alternative (ClearPath) would work with TM/PP.
    Thanks,
    Awall
    The Body Armor Dude - Andrew
