The contact rating is 24V. Full specs here:
Model: CS-100K-50
Output mode: A: NO(normally open)
Stroke: 5mm
Contact life: 3 million times
Waterproof level: IP 67
Repeated positioning accuracy: 0.001mm(operation : 50-200mm/min)
Contact force: 1.5N
Contact material: Hard alloy, tungsten steel
Cutter ia.50mm, Height 110mm/4.3in
Surface treatment: Grinding 4S
Contact rate: DC24V 20mA(), recommend 10mA resistive load
Cable: Standard oil proof cable(6 cores)
LED light: Often off, on when working
Power supply voltage: DC24V
Consumption current: 10mA
Output specification: DC60V 100mA(resistance load)/ AC60V 100mA()/ 500mW()
Overtravel alarm signal:
Output mode B: NC is normally (emergency stop when the signal is disconnected)
Contact voltage DC24V 20mA resistance load (load required under special circumstances, current limit)
Weight: Approx.906g/32oz
