A runout test bar is a lot more expensive that a Tormach spindle.
True, but do I need a test bar accurate to 0.1 micron? Or would 1 micron suffice?
Cheers
Roger
Cheers
Roger
For quick and dirty tests, I use a length of Thomson 60 case 3/4" in the Tormach Master Collet - they are pretty expensive and have decent straighness and roundness specs.
http://www.thomsonlinear.com/website...dard_shaft.php
I was
Also, I recommend you toss that Tormach r8 collet, I was checking the contact patch on mine and it was terrible. I also checked the collet from a different machine and it was bad, too. Contact barely 1/8 inch wide uneven patches next to the slits only. This is bad for the spindle taper since you are exerting a lot of pressure onto such small areas equal a lot of concentrated PSI. It starts doing damage. Get Hardinge collet and grind it down. I clamped my bench grinder on my Bridgeport and put a 3/4 inch delrin slug in the collet to close it down on then just slowly took very shallow passes.
you can get them here:
https://www.shophardinge.com/product...17570019007500
If they are out of stock the have a week or less lead time.
Test the contact patch on yours, hopefully yours will be better but I doubt it.
If the spindle taper has runout it is possible to re-cut it in place. Check out this post.
Can You Really Regrind Your Spindle While It's On the Machine? - CNCCookbook CNCCookbook
Well, maybe they will not be replacing the spindle. I sent videos of the spindle and they seem to be not sure if it warrants replacement. I have been back and forth with 2 people. One went on vacation, another took over so started everything off again. Thought we were gaining ground now I am back to the original person, picking up where we left off. I am pretty much over it. I am just going to send out the spindle. I asked them to just give me the bearing sizes so I can let the grinders know. Right now, time is of the essence, and it is much more important to fix this than the money. Plus the guy I spoke to will only regrind it if they change the bearings to some of their higher standards.
I was going to buy a second 1100 real soon and a lathe but I dont think this will happen. I would never tell them this to try and get this resolved sooner, though, just wanted it resolved. Having to mark the spindle and mark my holders to line them all the same every time is a real pain, especially when I have a lot of tool changes.
Oh well, if this is not resolved by the end of the week I will start to refocus towards something different and bigger. Maybe a VF2 or a Speedio.
I'll still keep the machine for prototyping and teaching my kids but no more Tormachs in my future.
They should really offer upgraded spindles with a certificate of concentricity to within a tenth or less with American bearings. I would gladly pay extra for that.
My finishes looked similar to this when I first got my 1100, the problem turned out to be severe vibration, I balanced the spindle PDB nut, drive motor fan, and changed the belt to a Fenner link belt, my finishes went from bad to good immediately.
I havent really checked for runout of the spindle on my machine, but my finishes look more like the top photo.
Keep us posted on what you find thats causing the problem.
mike sr
The previous machine I used had the exact same setup as mine. The only difference was that mine has runout at the taper and the other one had almost none. I have a part I was making where I was running a real nice high helix 3/16 cutter no prob on the previous machine that will snap it almost immediately on mine. You can hear the individual hits where only one side of the cutter is hitting. Plus I have measured it.
On one part, I run a 1.5 inch wide by 3/8 DOC keyseat cutter that has a little runout on the holder, nothing bad, like most tools on er collets. On one machine, no prob. On mine, you can hear the clunk, clunk, clunk... Its hitting on one side only most of the time unless I line the tools with the spindle just right so that the high side of a cutter matches the lowside of the spindle runout. Vibration from the belt is one thing, a tool running non-concentric is a whole other story
I have had 3 other milling machines. 2 bridgeports and a smaller mill, and 3 lathes.I have had a bunch of different pieces of machinery. I am not a great expert but i have been doing this for some years. I just got the Tormach to ease into the CNC world.
