You could also paint them with model paint. Red/Green on the toggle for power and blue for the coolant. I like the flip up cover.
And looking identical!
So I reset a program right in the middle of it. At least it was a small part.
This is my solution for now:
This is coming:
I'll eventually get this thing fully enclosed and will move all this away anyway but for now I will do the toggle switch and cover.
- Problem- Compare Mazak programs side by side with diferences highlighted.
- Newbie- Adjusting CRT Monitor side to side
- Need Help!- Drifting X-axis, making step ladders one side whereas other side is smooth- SOS
- Z-axis - mounting rails on spindle side, rather than tower side
- mounting linear rails side by side
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
I have the same gripe, I have turned off the computer many times thinking it was the coolant switch. I thought about using the key switch position for it, as I never use the key switch anyway.
mike sr
Add me to the list of people who have done that and trashed a part.
The coolant and interior light buttons are right next together on my turning center. More than once I've turned the coolant on with the door open while doing a setup. The coolant pressure and volume is just a bit more than a Tormach.
oddly enough, I think this is the one "operator induced error" I have not committed... I am feeling pretty good now knowing there is at least one thing I have not screwed up with my mill...
so, thanks for that
NOTE:As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists.
Sadly, many control panels look just like that. Geometrically arranged rows of buttons/switches with no consideration for ergonomics.
Imagine a car dashboard where you could accidentally switch off the engine instead of turning the windshield washer on.
I hit mine once, I had a really sad look on my face. I run heavy flood and the PLC cabinet doesn't have the greatest seal so I have put a piece of plastic over it. That has forced me to use the controls in path pilot. If you can force yourself to operate everything from there then you shouldn't make that mistake, it is working for me thus far.
LOL,
I realized that switch has no function on my mill. I use a ups on my machine controller and it cant lose power even if the power goes out
I must warn you those switches are handy but can be bumped with vac hose or leg and off they go. I use them most to power all the little gadgets,battery chargers, tablets, monitors and led task lights that end up on my work stations. Most cord power tools are plugged in on overhead cords.
I use mostly task lights these days. 1000 watts of overhead 4 ft lights generate to much heat and co$st money. Need to rewire them to be switched in banks so I can use sets over mill , bench, and jeep. Another project
Thanks! Always fun to share pics of where you practice your craft whatever it is. You should see my Swiss Army router, table saw And having a tormach mill makes it even better. I make tools, fixtures, attachments, guides, rulers, fences, sliding guides, offset stops.... the shop is half full of things that attach to it
Add me to the list. I've done it once. Now I keep the coolant switch on Auto and use the coolant button in PP instead.
Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
