Okay, I'm finally at the point now where running back and forth with the thumb drive (even though it's only 5 feet away) is getting old. Not to mention, how many times can you plug in and out of a port before you start to wear out the contacts?
So, I know there has been tons of discussion on this topic and most of it is waaaay above my pay-grade in computer skills, I'm looking for the Cliff Note version or at least a point in the right direction.
With PathPilot what is my best option right now for something reasonably easy to implement and does not require going in and tweaking line code to make it function?
Thanks,
Awall
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
Like this one?
https://www.tormach.com/store/index....show&ref=34705
I had a TP Link USB WiFi dongle laying about, plugged it in, followed the instructions for hooking it up to my home network, and to my utter amazement, my mill controller showed up on my list of servers (MacOS). Not sure what would be necessary under Windows, but there are instructions for that in the Tormach WiFi adapter manual.
Sent from my iPad using Tapatalk
silly question, but why go wireless adapter when you can just plug in an ethernet cable for free? what does buying a wireless adapter get you?
I just cant help but think these mills are not very portable, so picking the mill up and taking it with you to the bathroom seems somewhat slightly unwieldy...
why would you need the mill to be wireless?
NOTE:As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists.
To avoid pulling wire/cable through your garage/shop.
Pulling wire through my attic is not fun. Nor is running it through insulated walls. A $15 dongle saves buying cable, running it, expanding the network hub, any labor if you're a business having to pay someone to run the wire, etc.
The better question is "why run a wire when a USB dongle will do the same thing?" It's not a high bandwidth application so you don't need a 10Gbps wire to move tiny CAM files.
TP-Link TL-WN725N. $9.61 from Amazon. Hard to beat.
I have my computer mounted to my toolbox and drag it to whatever machine I am working on. That way I don't gotta run to get tools and/or run to make changes on the compu. I've got a UPS on here which buys me quite a bit of time before I need to plug back in. Wireless, for me anyways, is just more convenient.
