I think the problem/bug is related to using a spot drill instead of a chamfer tool. Until they fix the problem, try changing to a chamfer tool. There was a discussion on the facebook group.
Trying to use the 2D chamfer setting out of Fusion. I have the latest post file for PP and the latest update on F360. Anyone else having the feed=0? I've looked at every setting on the tool and in the dialog but cannot find out the issue.
Thanks,
Awall
(BAD-FEED)
(Z=STOCK TOP - XY=FLC)
(T46 D=0.25 CR=0. TAPER=90deg - ZMIN=-0.04 - spot drill)
N10 G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
N20 G20 (Inch)
N30 G30
(2D Chamfer4)
N50 G30
N60 T46 G43 H46 M6
(LSC 14 Mill - Drill)
N70 S3000 M3 M8
N80 G54
N90 G0 X0.145 Y-0.625
N100 G1 Z0.2 F0.
N110 G1 Z0.08
N120 G1 Z-0.04 F10.
N130 G1 Y-0.75 F0.
N140 G1 Y-0.9028 F25.
N150 G2 X0.1394 Y-0.9167 I-0.02 J0.
N160 G3 X0.1405 Y-0.9875 I0.0359 J-0.0348
N170 G3 X0.2113 Y-0.9862 I0.0347 J0.036
N180 G2 X0.2258 Y-0.98 I0.0144 J-0.0138
N190 G1 X1.3992
N200 G2 X1.4137 Y-0.9862 I0. J-0.02
N210 G3 X1.4845 Y-0.9875 I0.0361 J0.0346
N220 G3 X1.4856 Y-0.9167 I-0.0347 J0.036
N230 G2 X1.48 Y-0.9028 I0.0144 J0.0139
N240 G1 Y-0.75
N250 G1 Y-0.625 F0.
N260 G0 Z0.2
N270 G0 Y-0.125
N280 G1 Z0.08 F0.
N290 G1 Z-0.04 F10.
N300 G1 Y0. F0.
N310 G1 Y0.1528 F25.
N320 G2 X1.4856 Y0.1667 I0.02 J0.
N330 G3 X1.4845 Y0.2375 I-0.0359 J0.0348
N340 G3 X1.4137 Y0.2362 I-0.0347 J-0.036
N350 G2 X1.3992 Y0.23 I-0.0144 J0.0138
N360 G1 X0.2258
N370 G2 X0.2113 Y0.2362 I0. J0.02
N380 G3 X0.1405 Y0.2375 I-0.0361 J-0.0346
N390 G3 X0.1394 Y0.1667 I0.0347 J-0.036
N400 G2 X0.145 Y0.1528 I-0.0144 J-0.0139
N410 G1 Y0.
N420 G1 Y-0.125 F0.
N430 G0 Z0.2
N450 M5 M9
N460 G30
N470 M30
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
