Solved: Face Milling With Sprutcam
Results 1 to 2 of 2
Thread: Solved: Face Milling With Sprutcam
    Mar 2016
    Default Solved: Face Milling With Sprutcam
    I know for version 10 they have included the face milling operation and wanted to try it out. From the help menu there should be several different strategies, but when I look at the operations, I only have Tool, Feeds/Speeds and Template. I have just updated sprutcam but still no luck.
    Has anyone successfully tried the face milling operation and can tell me what I'm doing wrong?
    Attached Thumbnails Attached Thumbnails Solved: Face Milling With Sprutcam-face-milling-jpg   Solved: Face Milling With Sprutcam-face-milling-help-jpg
    Mar 2016
    Default Re: Solved: Face Milling With Sprutcam
    Found it. Everything is within the 'current operation property panel ' under strategies. Solved: Face Milling With Sprutcam-face-milling-solved-jpg
