A question for Keen, or anyone else who might know.
I plan to copy the gang tooling mounting plate Keen showed in his RapidTurn videos, and I would like to know the bolt circle dimensions of the spindle mounting bolts (M8's) that he used to attach the forward end of the plate.
Terry
That's exactly what I need! Thank you very much. If that came from the manual, I missed it somehow.
Terry
No worries Keen, I hadn't begun yet, too may irons in the fire. LoL
I'll be sure to check before I cut any metal,my machine is a series II, so it might have the same issue. The Tormach tool holder assy. is still on the spindle, so the bolts are obscured right now.
Terry
I'm looking for the similar drawing for a 770 but don't find it on the Tormach site. Any suggestions?
Thanks Keen, I think you mean the plate you made to attach to the spindle nose and to the rear of the head, not the plate that the RapidTurn is mounted on, correct?
Terry
That makes sense, I orient mine more to that side when I cut it.
Terry
