Try this calculator
Micro 100 Speed and Feed Calculator
I entered .180 cutter diameter 4 flute, put in a max rpm of 5000. You want the cutter diameter to calculate your feed rate, not the shaft size.
and its saying at 5000rpms, to run it at 25ipm. Delrin is very forgiving when it comes to thread milling, a great material to practice it on.
