The most important consideration with the tension/compression tapping head is the length of time that it takes the spindle to stop and reverse. If you are drilling through holes you have some chance of it working, otherwise in my experience, having run a series one machine for (must be) 10 years, you may find that it's faster and cheaper to tap the holes with a good electric drill: good luck though.
Sent from my XT1064 using Tapatalk
