I'm not sure what you mean by ''electrical interference filter'' Sometimes a choke or filter is installed external to the VFD, but I don't think there is anything like that in the VFD. When the VFD shuts down it will normally throw an error code, do you have any idea what the code is? My guess is your wiring is too small to handle the load without excessive voltage drop, or you have a bad neutral somewhere in your electrical system. I assume you are using 220 single phase power to the VFD.
