I would check the wiring between the PDB circuit board (in the little box on the top of the mill head) and the ATC Controller (in the back of the column) and make sure everything it plugged in (The RJ11 cable going from DB3 at the PDB controller to J5 on the ATC controller). If so, unplug the wire and check continuity between pins.
Sounds like an electrical connection problem.
