Originally Posted by
dobey
Think of the empty tool holder like using the Haimer in milling mode. Mine is tool 1 in milling mode and when you set the z height in mill mode with the Haimer it adds all the other tool offsets based on that number. So when you flip your part, switch back to the empty holder, be sure the machine is set on tool one, and reset your zero. All the other tools you have loaded are relative to that first tool. You really could do anything for tool one, even load a dial indicator in it (or probe) and use it just like in milling mode.
