How deep is the pocket?
If I were doing this I would:
1) Use the Tormach 25mm insert cutter with the short holder. This gives a reach of 1.9", run at 2500rpm, .100DOC, .700WOC, 50IPM. Reduce to 35IPM for full slotting.
2) Use the Tormach 25mm insert cutter with the medium holder. Reach is about 3.5", run at 3500rpm .030DOC, .700WOC, 70IPM.
3) If it's deeper that that, a 3/4 endmill directly in the R8 collet. Plunge cut for roughing followed by very light finishing passes. I've done that with a 3" flute length EM sticking out 4.5" from the spindle.
Good luck.
