Hang your head and send it over to me :P
Ahh hahahha... awesome... I wish I had thought of that.. I had pullout and buried an endmill in the table on my 1100 - twice. I used iron/epoxy stuff then hit it with a file. Kept junk out of the hole and worked fine. Every time I looked at it since though, it bugs me!
Be setting down when you read this thread and the many others that build on this site.
People like Rupnow and many others build different types of engines, some do one every couple months.
Quarter Scale Merlin V-12 - Home Model Engine Machinist
Enjoy
I have learned more from reading what these guys do then about any other single place on the net. Well I do learn a great deal here also!! just not as many cool tricks and setups....
So much info in a single picture on many of these threads
I finally got around to repairing the hole in my table, caused a year ago by stupidity and inexperience. I thought I'd share what I did for the repair to close the thread as 'complete'.
The best advice I got here (thanks!) was to plug the hole with a suitably 'similar' material and finish-it back to table level, so I turned-down a scrap of cast iron to make a 6mm diameter plug, about 6.5mm long. Then the tricky bit - milling-out the 4mm hole as carefully as possible using PathPilot conversational and a 4mm 4-flute carbide cutter, to a depth of 6mm, and 'walking-out' the (interpolated) diameter until the plug was a close push-fit. Then apply some Loctite 630 (shaft-fit) and knock-in the plug. After leaving overnight I then used an 8mm 6-flute carbide endmill to level-off the plug, but only after some careful checking of Z heights for the Haimer and tool. I was able to machine the plug down to 0.05mm above table height before chickening-out, then used my round Norton hand stone to do the rest. Here's a couple of pics of the inserted plug before finishing, though I wish I'd taken one of the original hole! Hopefully you can see the finished result which I'm pleased with. It'd not invisible, but you now have to look for it.
Cheers, Andy
Wow,
Looks like a sweat drop fell on the table!
What did you use for the cast iron, the color match is pretty good? Those round Norton Knife Stones are really hard to do without for maintaining tables.
gary
Thanks, Gary, I admit it turned-out better than expected. The cast-iron was just a bit of 'model engineering' scrap I acquired from somewhere, probably used to make steam pistons. It's sold as 'Meehanite 250' cast bar. I had to guess it was a reasonable match for the Tormach's bed material, the composition of which I can't determine. Yes, the Norton stone is just the tool for cleaning-up the table's surface in between jobs.
Cheers, Andy
That does look good! Nice job.
My table is fine, but the 5" CNC vise that Tormach sells now, is not the same size as what they used to sell (well, at least the jaws are different). You can probably guess how I figured that one out ;-)
Running the two side by side can be troublesome if I forget that.
