Originally Posted by
SCzEngrgGroup
I think you will find those suck (not in a good way), especially for intermittent operation. They depend on siphon action to get the coolant/oil to the nozzle, which makes them VERY dependent upon the height of the reservoir, relative to the venturi, the height of the fluid in the reservoir, and the viscosity of the fluid. And they need considerable time to "prime" after the air is turned on. When used with mist coolant (which is 90+% water), the amount of mist ejected is VERY inconsistent. And, the venturi and needle valve are VERY prone to clogging, which will usually completely **** off the fluid flow. I used several such systems for a long time, and HATED them all. The FogBuster is 10X better, but flood, while messy, is absolutely trouble-free and dead-reliable. A good MQL system will usually use a pressure, or positive displacement, pump to feed the fluid, to ensure a consistent, highly reliable flow.
Regards,
Ray L.
