Some considerations that you may not have thought of:
The 770 is a proven design (I've had my for over 3 years) so there should not be any surprises such as the recent issue of the spindle starting when PP crashes
There are many experienced users here who can help you over any problems
Some planned options are not yet available for the 440 including insofar as I know a PDB, ATC, 4th axis and automatic oiler
The RapidTurn isn't available for the 440
The work envelope of the 440 may be sufficient for now but needs change. You may want to make many small parts in one setup which is particularly advantageous if you don't have an ATC. Also, don't overlook the space required for clamps, long drill bits/reamers and tapping heads even when making small parts.
Just a few considerations. If you haven't guessed I'm a happy 770 owner!
