Video NEW DESIGN CRASH RESISTANT LOW COST TOUCH PROBE - Page 3
Page 3 of 10 FirstFirst 123456 ... LastLast
Results 25 to 36 of 113
Thread: NEW DESIGN CRASH RESISTANT LOW COST TOUCH PROBE
  1. #25
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    Default Re: NEW DESIGN CRASH RESISTANT LOW COST TOUCH PROBE
    where is the number 8 wire look's good
    Being Disabled is OK CNC is For fuN
  2. #26
    Feb 2007
    New Zealand
    Quote Originally Posted by Gravelleknives View Post
    I was able to remove a lot of the stylus deflection by getting new stylus's from renishaw. the one I have now is a 4mm X 15mm rod and 6mm ruby.
    Hi Gravelleknives.
    What sort of cost was that stylus?
    Keen
  3. #27
    Feb 2007
    New Zealand
    Quote Originally Posted by daniellyall View Post
    Gidday! I will try and add that. Keen
  4. #28
    May 2014
    Quote Originally Posted by keen View Post
    Hi Gravelleknives.
    Keen
    $60 iirc. The rod is carbide, its plenty stiff enough and a lot more forgiving with minor probing errors.
    Sent from my SM-G900V using Tapatalk
  5. #29
    Feb 2007
    New Zealand
    Hi Gravelleknives. Sorry to persist on this but was that the price of a new stylus from a Renishaw agent or via another outlet...ebay etc?
    Keen
  6. #30
    May 2014
    It was from renishaw, I live near there hq so I just went in a picked one out.
  7. #31
    Feb 2007
    New Zealand
    Hi Folks
    Sorry this has been such a long time - I have been busy developing a Mk3
    Cheers Keen
  8. #32
    Jan 2006
    UK
    Looks very interesting. How are you going to cope with shipping where the probe may spend several days in some arbitrary orientation?
    Dave.
  9. #33
    Feb 2007
    New Zealand
    Quote Originally Posted by davebaldwin View Post
    Dave.
    Hi Dave
    The plan is that the Probe will be user serviceable. I plan to link buyers to a non publicly listed technical video explaining applying the fluid and other technical details, and to perhaps supply the Probe with the end cap off, or on loosely...and a tube of the fluid - it only takes a minute to apply the lube and screw the end cap on.
    This will also mean buyers will have viewed and understand the construction and should be more comfortable with any future user service should that ever be required. For example should any contamination from coolant or dirt etc occur, they will still have the fluid and can clean it out and relube. ..or fit a replacement part if a massive crash occurs etc.
    Cheers Keen
  10. #34
    Jun 2005
    You might be able to vacuum package them which would probably not allow the fluid to move.
    Russ
  11. #35
    Feb 2007
    New Zealand
    Thanks for that Russ - food for thought.
    keen
  12. #36
    Apr 2016
    How about an access cover on the side and just put a few drops of ACF-50 on the contacts every few months?
