I think it really depends what you want to use it for. There's just several aspects of it that I don't like. Here's a few: Clamping your mold shut is crucial, a vice is just not a good tool for it. The clamping surfaces are pretty small so it will be difficult to clamp a larger mold and the max clamping force is quite limited. Unless you are using a very good flowing plastic (like HDPE) it might become difficult to fill a larger mold.
Also, the Z axis isn't that strong, so you don't have that much injection pressure. Aside from that, I wouldn't feel comfortable to put my Z-Axis stepper motor repeatedly under maximum load. Also, your can't use your mill while molding. If you need to make some adjustments to a mold, you have to remove the injection molder first.
All in all, I see the Tormach injection molder more as an educational tool.
