Mach 4
Page 1 of 4 1234 LastLast
Results 1 to 12 of 40
Thread: Mach 4
    Apr 2011
    Default Mach 4
    I have been using the new Mach 4 on my tormach for a couple weeks and really like it.
    Was very easy to transition from the Mach 3.
    Started using Cutter comp and its working great.
    Is there anyone else here on the CNC Zone forum running a tormach with Mach 4?
    Registered tmarks11's Avatar
    Jul 2004
    Default Re: Mach 4
    You using the PP plug-in?
    Tim
    Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
    Apr 2011
    Default Re: Mach 4
    I am not very knowlegable on the controls or software but believe PP refers to a parallel port and the answer is no.
    There is a smooth stepper I believe and a very nice pendant. The pendant makes setup up work easier and faster.
    Jul 2004
    Default Re: Mach 4
    sweet. I didn't realize the smooth-stepper plug-in had made it to prime time. Nice to hear a positive report. You using the ethernet SS, I presume?
    How hard was it to set it up to work on your tormach? Did you have to come up with the configuration or did warp9 come up with it?
    EDIT: I see the mach4 (beta) ESS plug-in was released yesterday (April 19). Good to finally see some mach4 plug-ins showing up.
    Tim
    Apr 2011
    Default Re: Mach 4
    Yes the smooth stepper plugs into the Ethernet port. Works very nice.
    Was very easy to set up. And like I said the transition from Mach 3 to Mach 4 was very easy also.
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    Default Re: Mach 4
    welcome to the M4 club
    Mach 4
    Being Disabled is OK CNC is For fuN
  7. #7
    Sep 2005
    Indonesia
    Default Re: Mach 4
    I am using mach3, can I just wipe out mach3 and install mach4 to run my hardware? Is that easy?
  8. #8
    Sep 2009
    New Zealand
    Default Re: Mach 4
    you use the same settings they are just put in differently what hardware do you have pp or what. it is easy as long as you don't expect it to be like M3 I did a M4 install to day it took 1 hour including testing.
    if you have a tormach same model and a ESS as op you could just use his profile easy as that
    Mach 4
  9. #9
    Sep 2005
    Indonesia
    Default Re: Mach 4
    I will have new controller and motor next month same as I have now, then I will try with Mach4 with this new machine..
  10. #10
    Registered CNC-Dude's Avatar
    Feb 2009
    Default Re: Mach 4
    For all of us ignoramus out there, can the MACH4er's tell us what we would need to upgrade to MACH4 other than the license? I am reading Smooth Stepper, Ethernet, etc. Seems like I need the SW, the license, some extra hardware and a Tormach compatible configuration file. Is there any place detailing the details?
    I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
  11. #11
    Apr 2011
    Quote Originally Posted by CNC-Dude View Post
    I believe RonGinger can answer those questions better than I.
    My understanding is there will be a mach 4 installer available for the tormach machines at some point.
    My tormach 1100 can also run on mach 3 with the mach 4 on the same computer.
    Both are in my tormach computer that came when I purchased the tormach 1100.
  12. #12
    Mar 2003
    Maine
    Default Re: Mach 4
    Mach3 and Mach4 can both be on the PC at the same time, they do not interfere in any way. So you can load M4 and try it out and still go back to your old M3 simply by clicking the right icon to start up.
    There is a parallel port driver for M4, but frankly I would switch to a hardware motion device. There are several available now, the Ethernet smoothstepper, a usbSmartBOB from PMDX.com and one from Poscope.com There are also a couple high end devices, like galil (sp?). These are out of my price range so I dont follow them.
    The Pokey device has the advantage of lots of input/output pins to hook up things like MPGs and other pendants.
    We were running a mini mill at the NAMES show this past weekend using the usbSmartBOB from PMDX.com This is a neat device, the entire motion control is in a slightly enlarged db25 connector hood, so you just plug it in to the back of the Tormach where the parallel port cable goes now and run a usb cable to the PC. Very simple to install, just download M4 from machsupport.com and the plugin form PMDX. To use the smoothstepper or pokey you will need an external 5v supply. There is work being done n a single box to hold a pokey which should be available in a week or two.
    M4 is a big improvement over M3- smoother, faster. Feedhold is instant, toolpath updates are fast and dont hurt running gcode. Things like cutter comp now work to industry standards.
Mach 4
Mach 4
