Mach 4 - Page 4
Page 4 of 4 FirstFirst 1234
Results 37 to 40 of 40
Thread: Mach 4
  1. #37
    Registered assadi's Avatar
    Feb 2015
    Default Re: Mach 4
    Hello, can I use the pokeys57cnc for plasma CNC ?! Can I wire the THC (miniTHC from Russia) to the DB-25 connection on pokeys57cnc ?!
    Sent from my A0001 using Tapatalk
  2. #38
    Registered tmarks11's Avatar
    Jul 2004
    Default Re: Mach 4
    Quote Originally Posted by assadi View Post
    Recommend you post this to the plasma cnc group. Won't get as much help here.
    http://www.cnczone.com/forums/plasma...e-project-log/
    Tim
    Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
  3. #39
    Aug 2015
    Default Re: Mach 4
    I recently switched my CSMIO from Mach 3 to Mach 4 on the Bridgeport Apollo I retroed.
    Much better motion profiles on corners and bores.
    And best of all no more crashes. Mach 3 would occasionally crash for no particular reason.
  4. #40
    Gold Member Steve Seebold's Avatar
    Mar 2009
    USA and proud of it
    Quote Originally Posted by yourout View Post
    Dang, I have run my 1100 with Mach III for 6 1/2 years and “never” had a glitch. And I get into some pretty technical stuff. I don’t cut steel on my machine but I cut a lot of 718 Inconel and 6AL-4V titanium.
    When I had my shop I used to solicit exotic material jobs because no one wanted to do it.
    I spent the time and the money to learn how to cut the exotics and I actually did pretty well with it.
Mach 4
Mach 4
