Originally Posted by
cordvision
The radius was about 4-5 inches (little less than 10 inch diameter). Being 0.012" out of tram without shims seams really extreme since it should be possible to get it within 0.0005" (60x less).
I tried to support the base only on 3 points by putting a support between the left two pads. This meant that the mill was only sitting on the right two pads and the support block between the left two pads.
How would you compare the tram of the spindle to the vertical motion of the head?
