My free Online FSWizard calculator has what you describe.
Go to FSWizard - Free Advanced CNC Speed and Feed Calculator and on the myCut DB select "User Database".
Then check Diameter, tool material column.
Then start dialing in the tool you had in mind.
MyCut DB table will filter out calculations saved by other users based on the columns you have checked.
Pay attention to the saved cuts that have speed/feed override set up as it means that user probably saved the cut the way he was actually running it.
