Have you checked the fuse? Its a 6A fuse for the auxiliary circuit. Don't know what kind of fuse it is, but I can think its a glass-fuse (small one).
Im not sure what happened, but when I went to plug in my coolant system none of the plugs would work. Is this a problem anyone has dealt with? Any way to fix it?
Thanks in advance, guys!
Are you using the Tormach coolant system? If you are using something else what is the current rating for the pump?
Mike
If you don't know how to test the continuity of a single phase supply then best to call an electrician. Oh I wonder if the fuse has blown. Come on sunshine put your brain in gear.
Phil
The 120 is suggested to be plugged into a GFI outlet. If so is it tripped? The outlet furthest from the column is for the coolant pump and thus controlled by cnc if i understand correctly. Does the computer power up when plugged back there?
