I've been reading the manuals related to the coolant pump...but I can't find anything beside that it runs on 115VAC.
But since the fuse is only 5amps, and its for running the computer and the coolant pump, I don't think that the coolant pump is anything more than 200W.
A general computer with a screen today usually consumes about 300W of power, that leaves about 100-150W for the coolant pump..the rest of the amperage on the fuse is for the peak current when turning youre power supply on, for the computer.(Just theory and wishes due to the text below)
Luckily I found a 115VA transformer in my basement.
A 230/115 transformer in Norway is more costly than a new 230VAC pump itself.
But running a 90l/min (smallest one I found locally) pump on the tormach needs a big pool for coolant, so im opting for the original one with my 115VA transformer.
Still hoping that someone can throw in some info on the original coolant pump that is included with the PCNC1100 Deluxe Machine Stand
