Tool depth setter is a must have if you have ATC, hmmm what do you already have?
I have a Tormach discount voucher burning a hole in my pocket any recommendations on accessory must haves?
As I am an expert on burning tools out I was thinking the load meter might be helpful?
The load meter won't help if your problem is that you're already running too slow and rubbing your tools to death.
edit: Actually it could help you significantly if it gave you the confidence to run faster.
Where on earth did you find a Tormach discount voucher?
Phil
+1 ???
Maybe Tormach Workshops
*Students who complete the course will receive a coupon for a 20% discount ($200.00 max) redeemable for Tormach products. The coupon is non-transferable and must be used within six months of the date of the workshop attended. Limit one coupon per invoice.
David
Got it in one David
I don’t rub tools to death once I get the speeds and feed sorted its monitoring tool wear I guess it might be useful for.
More ideas I have is some if there indexing tooling, but its expensive. A tool height setter but do I really need it? I don’t have an ATC and re-setting the Z height when tool changing is not that big a deal. Then again which one, there seem to be two electronic versions now.
