Need Help! Thread Milling - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Thread Milling
  1. #21
    Jul 2004
    Quote Originally Posted by DareBee View Post
    definite kudos Neil.
    I didn't look at it close enough to notice it was homespun (til now).
    The usual suppliers make these indexable single point tools as well for those that don't want to machine their own.
    Back at the OP.
    105 holes @ 1/2-20 in 4140HT, I strongly suggest you get a thread mill and just be done with it. You will be very pleased with the result and will likely save the cost of the thread mill in labour alone (not to mention the number of taps you will burn out).
    Darebee, any chance you can link to an example that would work the way Neil is using his with the right geometry when mounted in a mill? I would much rather purchase if reasonably priced.
    David
  2. #22
  3. #23
    Jun 2006
    Quote Originally Posted by wbleeker View Post
    It seems that MSC thinks there are only two other countries in the world Canada and Mexico? I tried to register and that is what wouldn't let me, who blew the rest of the world up?
    Will
    Will,
    Yes MSC don't like the bother of exporting off-shore due to US Government restrictions exporting technology to foreign countries. It seems they get enough business from home states (and Canada, Mexico) that they don't need to make the effort to filter the overseas orders to prevent high tech transfer.
    With the US dollar the way it is at present, MSC is losing business.
    Bevin
  4. #24
    Oct 2006
    Quote Originally Posted by bevinp View Post
    Will,
    Bevin
    Yes Bevin
    Too right they are losing money, I would be only too happy to buy off them and the way our dollar is at the moment so would plenty of others!
    Will
  5. #25
    Member neilw20's Avatar
    Jun 2007
    Look at the UK link. It is not blocked.
    MSC Industrial Supply Co.
    Damn !! Expensive, aren't they!!
    Stock levels, almost zero!! What service. Bet they get them from the US.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
  6. #26
    May 2009
    UK
    Default Re: Thread Milling
    Neil, I know this goes back a bit, but what inserts do you use please? I'd like to make one of these but a size smaller to do M14.
    John (in UK)
  7. #27
    Member kstrauss's Avatar
    Apr 2013
    Thanks for reviving an old thread! Neil mentioned that "The angular error in the thread form is trivial for most applications." Any suggestions regarding how this is determined? Web page perhaps?
  8. #28
    Jun 2007
    Quote Originally Posted by JohnHaine View Post
    John (in UK)
    Triangular. You need to design around the smaller insert. Top of insert on centerline. Before use the front clearance angle needs a little grind or it won't work. I designed by first creating accurate model of insert, the position correctly on axis. Then the holder was modeled around it. The screw is moved 0.1mn back towards apex of triangle so the it pulls in firmly.
  9. #29
    Member Steve Seebold's Avatar
    Mar 2009
    USA and proud of it
    How hard is the material you’re going to be cutting? You might be better off trying to tap your holes.
Thread Milling
Thread Milling
