I would like to try to help you out as I have seen my rotary axis run much faster than this. Let me first say that changing settings in config files can cause your machine to not work properly and Tormach more than likely has reasons for doing things the way they do, but I am a tinkerer at heart and want to know details and the "behind the curtain" of the things I own. Backup anything before you open or change it.
now, that being said-- Goto your folder C:\PCNC3 and look for a file named PCNC770M3.xml (I have the PCNC770, if you have the 1100 your file name might be something like PCNC1100M3.xml, I dunno). IE wants to open it to view, but you'll probably need to open in notepad to edit.
Look for the line:
<Vel3>21.67</Vel3>
Mine is 21.67 by default, What is yours? (I don't recall off hand what unit this value is in, but it directly relates to your DPM)
I have since upped it some. I haven't timed it, but it sure seems to be more than 1300 DPM.. more like 2000.
Note that I am running a Smoothstepper so I am not limited by the parallel port for step rate limitations. Tormach might have very well limited the rate to stay within the computer's parallel port speed, but that just seems painfully slow. The 21.67 value is default in mine, so you should at least be able to hit that value in yours.
