I wrote it, and it's very simple. I've attached a UDL file that you can import. Before you import, you will need to change the extension from ".txt" to ".xml". Seems the system wouldn't let me upload an XML file. To import:
Select "View", "User-Defined Dialogue..."
Click the "Import..." button
Select the file "GCode_UDL.xml"
When you see it, you won't believe how simple it is. That UDL file specifies that all files with the extension ".tap" are considered GCode files, and the formatting will be applied when they are opened in the editor.
