PP2.0 install USB boot frustration - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: PP2.0 install USB boot frustration
  1. #21
    Jan 2016
    Default Re: PP2.0 install USB boot frustration
    I am glad that worked for you. Hopefully, it will help others.
  2. #22
    Feb 2009
    Awesome news
    Just did it with the VirtualBox and was able to install.
    I did have issues when using the Tormach Original USB stick.
    I did a .img of the usb stick when i first got it.
    Made a new USB stick and it worked on for the Virtual.
    Will test this on the HP box. and report back
    Nick
  3. #23
    Jan 2016
    How are you guys making the .img of the PP2.0 usb disk?
  4. #24
    Jan 2007
    Quote Originally Posted by Steve303 View Post
    I used PassMark ImageUSB V1.3 to create an image and then wrote it to a kingston 16G stick, didn't want to touch the Tormach PP2 one very much in case I screwed it up
    M
  5. #25
    Feb 2009
    I use win32 Disk Imager for the same reason as Mooser.
  6. #26
    Member ShortTrack's Avatar
    Aug 2006
    An update to an old post, I know, but I ran into a similar problem yesterday - ALL DAY yesterday!!.
    I hope this might help others.
    Path Pilot Item #38706 simply would not boot my Tormach Controller - an HP dc5700 computer.
    I took the controller hard disk drive and put it in another computer, changed it's BIOS to allow booting from USB, and that worked.
    Then put the disk drive back in the original computer.
    I did contact TORMACH, about this, and their reply focused on BIOS settings regarding boot order and USB boot.
    Regards,
    -ST
