- Newbie- Update MOBO that work with Path Pilot and Linux?
I had found the original threads back in 2015 however none of the 4 MOBO have been made. To be quiet honest I rather build my PC because it will be cheaper and better than the 800 dollars I would spend with Tormach.
I'm still looking to see what touch monitors work in case anyone knows. Thanks in advance.
Re: Update MOBO that work with Path Pilot and Linux?
This is the 17" monitor. Right now it is $159.95. Works great with PathPilot. Can't help with the MOBO.
17-Inch 5-Wire Resistive LCD Touch Screen Monitor (4:3)
- You may not post replies
- You may not edit your posts
Forum Rules
