- Gnome Panel, Another Path
I have used the left shift = Alt on startup method to get to the Gnome panel but it is a hit or miss proposition; annoying to say the least.
Today, I discovered an alternate method. When Path Pilot is shut down and you click on the OK button, immediately press and hold shift + alt. The Gnome panel appears.
RJ
Re: Gnome Panel, Another Path
If I want to get to the desktop or terminal from Pathpilot, I hit the exit button in Pathpilot then the Linux header appears at the top of the screen, then navigate from there.
- You may not post replies
- You may not edit your posts
Forum Rules
