PathPilot 2.x and PathPilot Simulator - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 99
Thread: PathPilot 2.x and PathPilot Simulator
  1. #61
    Jul 2016
    Default Re: PathPilot 2.x and PathPilot Simulator
    No idea. Someone from Tormach contacted me on FB because of the PP customization I've been working on. They suggested that I participate in the beta. That's all I know.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
  2. #62
    Apr 2017
    Now that I have the simulator working (thanks again, @sharmstr), I am thinking about the best ways to keep it and my real PathPilot synchronized. Is there a known way to load & save the Offsets table from & to a file?
  3. #63
    Jul 2016
    Operator/mill_data/tool.tbl is the comma separated file which is your tool table.
  4. #64
    Member kstrauss's Avatar
    Apr 2013
    Also, I assume that you could use admin settings backup on one instance and admin settings restore on the other instance.
  5. #65
    Apr 2017
    I've looked at the simulator's Operator/mill_data/tool.tbl file, and it has only a subset of the information that is visible from within the simulator. For example, the simulator has
    but the pertinent section of the Operator/mill_data/tool.tbl file shows the OD, but not the description:
    Is there another file with the descriptions?
    Attached Thumbnails Attached Thumbnails PathPilot 2.x and PathPilot Simulator-simulator-view-jpg   PathPilot 2.x and PathPilot Simulator-tooltbl-file-jpg
  6. #66
    Apr 2013
    The description is in a separate database rather than flat file. That is why I suggested that the ADMIN SETTINGS BACKUP command might be better. The tool table flat file together with the database are combined into a .zip for the backup.
  7. #67
    Apr 2017
    Quote Originally Posted by kstrauss View Post
    That's the best solution. Thanks.
  8. #68
    Mar 2012
    Quote Originally Posted by sharmstr View Post
    A company that sees you are working on improvements to their product and instead of shunning you they invite you to participate and help them improve. Good to see. Three cheers for Tormach.
  9. #69
    Jan 2016
    Is there an available screen editor for PathPilot like there is for Mach3?
  10. #70
    Jul 2016
    I'm not experienced enough to give you a detailed answer, but I'd say no. The PP ui was done with glade. Really old versions of everything so it was hard to find installers. I tried to use it to modify PP but I found it cumbersome so I'm editing the files directly with Notepad ++ and Scribes. Hopefully PP 2.0 is using gtk3 and running on a newer version of linuxcnc, ubuntu, and glade. That might make it worthwhile to learn glade. I didnt know any of this 2 weeks ago, so take it with a grain of salt.
  11. #71
    Jan 2016
    Thanks for the info. I've heard of glade but have never touched it before.
  12. #72
    Jul 2016
    I received the 2.0 beta USB yesterday. I dont see a reason to do another install video as there only a few differences in installing on a VB client.
    - I couldnt get it to install on a 32 bit client. When you create your client, select 64 bit. All the other settings (memory and disk size) are the same
    - VirtualBox doesnt allow you to boot to the USB for install. To get around that, you can download Plop Boot Manager (https://www.plop.at/en/bootmanager/download.html) to your host. Extract the zip, then mount the iso (plpbt.iso) to your client as well as your usb drive. Start the client and select USB on the boot menu. The PP install is the same after that. Once the PP installer is finished, unmount plpbt.iso and restart.
    - I didnt have to change the config file to tell PP to launch in sim mode.
    That's it if you just want PP to run. If, however, you dont want PP to launch at startup there are a few more differences
    - /usr/bin/mate-panel instead of /usr/bin/gnome-panel
    - "Startup Applications" is now in All Applications
    - To crate the PP launcher, use "mate-terminal -x bash -c "~/operator_login"
    side note: Host shared folders no longer show up in PP
    EDIT: You can create a link to the hosts shared folders in your gcode directory. Open up terminal and run the following command. Change the share names to match yours
    sudo ln -s /media/your_host_share_name /home/operator/gcode/whatever_name_here
    Now when you go to the file tab in PP, you'll see your shared folder in the left window instead of the USB window. And now that I think about this, its probably a better way of doing it even in v1.9.13
    Last edited by sharmstr; 11-03-2017 at 11:06 AM. Reason: added work around for host shared folders
  13. #73
    Apr 2013
    What version of Ubuntu does the beta use?
  14. #74
    Member Contract_Pilot's Avatar
    Jan 2009
    kstrauss, no one is willing to say I guess! I would assume Debian Debian 7.0 Wheezy because that is what the current version of LCNC uses.
    But there is also Debian 8.0 Jessie is from 2015 and Debian 9.0 is 2017.
    CNC Machines: Tormach PCNC 1100 CNC Mill W4th Axis | Birmingham 12X36 Lathe W/ CNC Retrofit W/Tormach BOB PathPilot & SKCD200220 VFD | My Personal Blog www.stevenrhine.com
  15. #75
    Dec 2014
    So what is potentially new in path pilot 2.0 other than OS updated?
  16. #76
    Jan 2009
    Just spoke with Tormach tech support. They said no state secret! PP 2.0 should be public in a couple weeks...
  17. #77
    Jan 2007
    potentially silly question
    In the simulator, PP doesn't "see" my USB stick with programs on it to test. How do I get it to "see" the USB or where do I copy files to on the HD for them to show up to load into PP
    Thx
    M
  18. #78
    Jan 2016
    Quote Originally Posted by Mooser View Post
    Thx
    M
    See post #29 for the USB Key. You also want to turn on Shared folders. Watch Sharmstr's video if you haven't.
  19. #79
    Jan 2007
    Thanks, didn't see the bit about having to add the device
    M
  20. #80
    Nov 2016
    Thanks for this info. I was able to install PP on my MacBook under Parallels, directly from the PP CD.
    1. Created ISO file from PP CD using Disk Utility.
    2. Added VM in Parallels, selecting the ISO file as media.
    3. Set memory to 2GB and HDD to 32GB.
    4. Install ran from start to finish.
    5. Selected Mill, MESA error, hit ok.
    6. Restarted VM and held down Fn-LSHIFT-Alt at Tormach Splash Screen
    7. Changed config as noted and restarted VM.
    8. Everything is functional.
    Quote Originally Posted by rdsi View Post
    There are a few things to be aware of:
    1) Create a Linux, Ubuntu (32-bit) virtual machine with 2048 MB of memory.
    2) You must create a “Fixed size” VDI disk image of 32GB.
    You can install from the CD or an ISO image of it. Earlier releases of the PP CD were not VB aware. The installation will look for the MESA hardware & bomb out if not found. You can get around this by booting into the Ubuntu desktop – hold down the left shift-alt keys. Then edit the file:
    “/home/operator/config_file.txt
    so that it contains 1 line of either:
    ~/tmc/configs/tormach_lathe/tormach_lathe_sim.ini
    or
    ~/tmc/configs/tormach_mill/tormach_mill_sim.ini
    and save it.
    Reboot and thing should work right. Now update to one of the later versions of PP so you don’t have to mess with this anymore.
    Also, you need to install the VB Guest Additions to get the screen size right and other features to work.
    I also fixed it so that I always boot into the desktop rather directly into PP. Then I have a desktop launcher for PP. This launcher runs PP in a fixed size window on my VB desktop so that's why my screen shot looks the way it does.
    Hope this helps ...
