PP Toolchange issue/question
Results 1 to 10 of 10
Thread: PP Toolchange issue/question
    Dec 2009
    Default PP Toolchange issue/question
    After 7 years of running Mach3 on my Novakon NM200 mill, I've undertaken a conversion. Other than getting the spindle speed correct, it's about done.
    Today I loaded a gcode program that I previously ran successfully on Mach3 and ran it under PP without the spindle running. It all looked good Except PP did not stop at the first M6 command. I'm wondering if PP assumes that the first tool is loaded when the program starts. Settings specified manual tool change.
    Member kstrauss's Avatar
    Apr 2013
    Default Re: PP Toolchange issue/question
    PP remembers the current tool when a new gcode program is loaded. It definitely stops for a tool change if required There is no stop if it knows that the right tool is loaded.
    Dec 2009
    That makes sense. Since I don't have an ATC, I typically just number the tools for a job starting at 1. If the previous file just had one tool, PP will start with T1, hence no stopping.
    It's not a big deal anyway since obviously I'd have the correct tool mounted before starting the program, but I was surprised after years of seeing execution stop at the first M6.
    Gold Member LeeWay's Avatar
    Jun 2004
    If you want or need it to stop, just insert an M0 before the M6.
    Then make sure it is check marked. This will pause the program at any point that you wish and wait for manual input to start again. Pretty useful sometimes.
    Lee
    Dec 2009
    When I try this I am unable to jog while stopped waiting at either the M0 or M6. Is there a way to enable jogging while stopped within a program?
    Member popspipes's Avatar
    Jun 2014
    Quote Originally Posted by kvom View Post
    Pausing the program, it does just that, the axes will not move.
    I think tool changes are the same.
    The only way I can set a different offset or tool is to stop the program, insert the new tool and offset and restart the program either from the beginning or use the find txx and restart the program from there.
    mike sr
  7. #7
    Apr 2013
    I don't know of a way to jog when paused or waiting for a tool change. The head will automatically go to the tool change position. Why do you need to jog?
  8. #8
    Jun 2004
    I haven't tried it, but I wonder if you can input any MDI commands under a pause?
    Lee
  9. #9
    Dec 2009
    Quote Originally Posted by kstrauss View Post
    No TTS holders so no tool table. I need to zero Z on each tool change.
    I did verify that stopping at an M6, which rewinds the program, allows jogging. So I can zero the new tool's Z and restart at the proper M6 line should work.
  10. #10
    Sep 2005
    The issue with performing a new zero setting on tool change has been discussed here in several posts. Basically PP is different from MACH and requires use of the tool table for tool changes within a program. A work around is to create a separate program for each tool or mess around. There are other messy options which you can find with a search. PP is a great improvement, but the lack of this feature also frustrates me at times.
    Robert
