Pathpilot seems to stop on a peck drill cycle...
Results 1 to 7 of 7
Thread: Pathpilot seems to stop on a peck drill cycle...
    Mar 2009
    Default Pathpilot seems to stop on a peck drill cycle...
    I'm using PathPilot on a non Tormach machine (Novakon Torus Pro). All axis's are moving. Mill is responding to move commands.
    I've built my gCode with Fusion 360 using the "Generic Tormach PathPilot" post. My mill seems to stop on the following line.
    N130 G98 G81 X4.636 Y-0.0876 Z-0.025 R0.2 F13.1
    Any thoughts?
    Here is all the code above that line...
    (1001)
    (T3 D=0.375 CR=0. - ZMIN=-0.1246 - flat end mill)
    (T4 D=0.125 CR=0. - ZMIN=-0.125 - flat end mill)
    (T12 D=0.125 CR=0. TAPER=118deg - ZMIN=-0.2626 - drill)
    (T22 D=0.375 CR=0. TAPER=90deg - ZMIN=-0.05 - spot drill)
    N10 G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
    N20 G20 (Inch)
    N30 G30
    (Drill1)
    N50 G30
    N60 T22 G43 H22 M6
    N70 S1500 M3 M8
    N80 G54
    N90 G0 X4.636 Y-0.0876
    N100 G0 Z0.6
    N120 G0 Z0.2
    N140 X4.
    N150 X2.706 Y-0.544
    N160 Y-1.206
    N170 X4. Y-1.6624
    N180 X4.636
    N190 G80
    N200 G0 Z0.6
    N220 M5 M9
    N230 G30
    Instructional Videos for CNC Guitar Building
    http://www.rmgvideos.com
    Dec 2013
    Default Re: Pathpilot seems to stop on a peck drill cycle...
    Try editing it like this and see what happens.
    N130 G98
    N135 G81 X4.636 Y-0.0876 Z-0.025 R0.2 F13.1
    Mar 2009
    Quote Originally Posted by Jim Dawson View Post
    N130 G98
    [/COLOR]
    Jim, thanks for the reply...
    Did that... Slightly changed the operation. If I single step the program it steps to the G98, executes it, steps to the next line (the G81) and the cursor goes back to G98 and stops...
    Scott...
    Dec 2013
    I don't see anything wrong with that G code. The the only other thing that comes to mind is remove the G98 all together and see how it reacts. According to the Tormach tutorial, that original line of code is correct.
    Mar 2009
    Thanks again... I found the problem. Added the following to my .hal file (found a reference to waiting for spindle to come to speed). My spindle speed is always showing 250 now, so I have something else to fix, but at least it made it past this point... .hal file attached in case you wanna look.
    # speed-out is displayed by UI when program running
    net spindle-speed-fb-rpm tormachspindle.speed-out
    # spindle at speed parameters for tormachspindle component
    setp tormachspindle.startup-delay [SPINDLE]STARTUP_DELAY
    # time to reach max speed from stopped
    setp tormachspindle.seconds-to-max-rpm [SPINDLE]SECONDS_TO_MAX_RPM
    # connect spindle comp at-speed output to motion
    net spindle-at-speed tormachspindle.at-speed motion.spindle-at-speed
    Scott...
    Attached Files Attached Files
    Dec 2013
    Happy to hear you found it. I would have never thought of that.
  7. #7
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by sagreen View Post
    Scott...
    A G81 is not a peck cycle you need to use a G73 or a G83 for a peck cycle, in the norm for a peck cycle, the correct way to format the code is G73G98X4.636 Y-0.0876 Z-0.025 R0.2 F13.1, the G73G98 can be swapped around, but this is the preferred Format for most controls
    Mactec54
