2 solid red lights is a bad sign, It means the FPGA could not load its configuration from the flash memory chip on board.
The most likely causes for this are:
1. PC 3.3V lower than 3.1V so FPGA never gets out of reset (if this is the case the card will work in a different PC)
2. Failed (leaky) Flash EEPROM memory (this is pretty insidious as bad chips work for a week, a month or a year but slowly forget their programming)
In case 1 the PC or PC power supply must be replaced, in case 2 the 5I25/6I25 must be repaired/replaced
