- PP 1.9.12 is available
PathPilot™ v1.9.12 Now Available
PathPilot v1.9.12 is now available for download from Tormach.com
In This Version-
Please be sure to read the release notes for a complete summary of all enhancements and bug fixes.
Enhancements:
All Machines
• Hidden files are no longer displayed by default under File tab.
• Spindle FWD and REV buttons have been enhanced so that they now only operate when you are in the Main tab.
Mills
• Tap/Drill tab - Location table mathematical expressions are now evaluated like they are in DRO fields.
Lathe
• In the Settings tab, the Keyboard Jogging Disable checkbox has been removed
Fixed Issues:
All Machines
• M01 breaks added after tool changes in Conversational
• Copying files with hidden files causes crash
• PathPilot does not start if custom data thread file is not present
• File tab - file list in window resets and scrolls to the top
• Conversation Edit: Insert File button does not accept hand-coded G-code
• Main tab: double-click of G-code edit window does not correctly resize with M01 image break
• Spindle Controls should only be operational while in Main tab.
• Cannot remove multiple selections involving directories
• Feedrate Override sliders read zero when the feedrate is less than one percent but not quite zero
• M00 picture display is a blank white screen
• Touch screen calibration settings are not saved with an ADMIN SETTINGS BACKUP or an ADMIN
SETTINGS RESTORE command
• Netbios samba machine name is not saved with an ADMIN SETTINGS BACKUP or an ADMIN SETTINGS
RESTORE command
• Job Assignment: Can’t insert a CAM-generated G-code file
• The highlighted active line is incorrect at M01 after no motion
Mills
• Probing: non-operational buttons with shortened axes's soft limits
• ATC: crash possible when loading a tool not assigned to tray
Lathe
• Conversational Threading: wrong tool path generated with quick change tool post
• Conversational Threading: The focus chain does not go to all DRO fields.
• Only supports one USB I/O board
• F1 toggle key missing from lathe configurations
For release notes and more information on this version as well as issue tracking and reporting visit the PathPilot Software Center.
Re: PP 1.9.12 is available
The release notes on the web site say that Images in Comments now work for the Lathe, but I don't see it in your release notes and tried it and cannot get it to work.
Pretty simple gcode. and I have placed the partsetup.jpg file all over the place and no dice.
( Test Program for images )
T 0303
M01 ( partsetup.jpg )
G0X0Z0 ( Move tool so we can position the part )
If I remove the blank lines from your test program, it works and I see an image.
Interesting. It does for me too once I remove the blanks and any other txt from the comment. Are blank lines bad?
Also, you cannot have a (msg,xxx) in the same line as a picture comment, and you cannot have a (msg, comment) right before the picture comment.
But, I can work around those as this works.
T 0303
M01 ( msg, Place nozzle as shown)
- You may not post replies
- You may not edit your posts
Forum Rules
