- Part counter
Banned
Part counter
When working with the bar puller on the lathe using the parts counter ( O103 repeat and endrepeat) and you have to reset to do some minor changes to the program, is there a way to know how many parts are machined and start the program to continue where I stopped it.
If I programmed 10 parts and stopped the program after 5 parts, can I start the program and tell pathpilot, you already made 5 parts, make the reamaining 5 parts.
Hope my question makes sense,
Jeff
Re: Part counter
In a recent Tormach video Daniel Rogge talked about using one of the extra axis DROs on the mill as a parts counter
Perhaps you could make that approach work on a lathe. Set the DRO to the number of parts you want and decrement to 0. It might be a clean way of adapting to different bar lengths.
bob
- Part counter
- You may not post replies
- You may not edit your posts
Forum Rules
