I had that too and it annoyed me so I use the USB drive to transfer files to then create a directory for each job or multiple ops then copy from USB to that directory and delete the old ones. I was able to clean up the root directory of older or less used files...
Maybe that could work for you.
The update I can now find is for 1.9.10, I downloaded it and installed it on the machine, everything seems fine except I cant set backlash for any axes in the tormach ini file, I updated to 1.9.8 and it works fine again.
Anyone else have a problem updating?
I cant find 1.9.11 on their site either for download, it was there a few days ago but not now?
any info appreciated........
mike sr
If Iclick on the link I have posted, I go to the TGP update files.
Jeff
This is what I see if I open the link
Jeff
mike sr
Cookies and Chrome? not a good combination!
You got me worried about the backlash correction so I quickly upgraded to 1.9.8, 1..9.10 and then 1.9.11. Backlash correction appeared to be operating with all 3 versions.
Perhaps you should recheck the changes to your ini file.
Step
Step
I think it didnt install correctly was what happened...... there were a couple other things that didnt seem right in the install procedure even though it did say I had 1.9.10 installed, I just reloaded 1.9.8 and all was good.
I now have 1.9.11 on my update thumb drive to try tomorrow. I really dont need it but it is something new and I am a sucker for that ha!!
I really wish the updates didnt erase all my personal modifications to the .ini file and my Ninja Knobs pendant files.
mike sr
