Installing LB-Link Wireless Adapter - need root password
Results 1 to 3 of 3
Thread: Installing LB-Link Wireless Adapter - need root password
    Member scott216's Avatar
    Apr 2012
    Default Installing LB-Link Wireless Adapter - need root password
    I'm trying to install an LB-Link wireless adapter (P/N BL-LW05-AR5). I downloaded the drivers here: LB-LINK BL-LW05-AR5 Driver (Linux / MAC / WIN CE)
    There's an install.sh script that is asking for root password, but I don't know it.
    The line in the script that's asking for root is:
    su -c make; Error=$?
    Anyone know the root password? If not, can I just change the above line to
    sudo make;
    Here's the install.sh file.
    Code:
    #!/bin/bash
    # Writed by Realtek : willisTang
    # September, 1 2010 v 1.0.0
    echo "		Auto install for 8192cu"
    echo "		September, 1 2010 v 1.0.0"
    cd driver
    Drvfoulder=`ls |grep .tar.gz`
    tar zxvf $Drvfoulder
    Drvfoulder=`ls |grep -iv '.tar.gz'`
    echo "$Drvfoulder"
    cd  $Drvfoulder
    echo "Authentication requested [root] for make driver:"
    if [ "`uname -r |grep fc`" == " " ]; then
    	sudo su -c make; Error=$?
    else
    fi
    module=`ls |grep -i 'ko'`
    if [ "$Error" != 0 ];then
    	echo "Compile make driver error: $Error, Please check error Mesg"
    	read REPLY
    	exit
    else
    	echo "Compile make driver ok!!"
    fi
    	echo "Authentication requested [root] for remove driver:"
    	sudo su -c "rmmod $module"
    	echo "Authentication requested [root] for insert driver:"
    	sudo su -c "insmod $module"
    	echo "Authentication requested [root] for install driver:"
    	sudo su -c "make install"
    else
    fi
    echo "################################################################"
    echo "The Setup Script is completed !"
    echo "Plese Press any keyword to exit."
    read REPLY
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Jun 2005
    Default Re: Installing LB-Link Wireless Adapter - need root password
    It's Ubuntu so it wants you to use sudo.
    Apr 2012
    Thanks. using sudo seems to have done the trick.
