What would you like to be added to the pathpilot software - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 65
Thread: What would you like to be added to the pathpilot software
  1. #41
    Nov 2012
    united states
    I've done changes on models and molds where I needed to blend to the surface without violating the surface. Having the ability to jog the machine while the cutter pass is running makes this process easier.
  2. #42
    Apr 2013
    Default Re: What would you like to be added to the pathpilot software
    Quote Originally Posted by tmarks11 View Post
    Add more keyboard shortcuts (or just add back in the normal linux cnc ones).
    I'd really like customizable shortcuts.
  3. #43
    Jan 2007
    Non-conversational spot where I could just straight type in code.
    Control of coolant in conv. screens
  4. #44
    Mar 2013
    U.S.
    A better editor would be nice. I find the included one to be awkward.
  5. #45
    Oct 2010
    The desire is to be able to zero a new tool when you install it during a tool change.
    That was a nice feature in Mach. There is a workaround I use ( actually have used a lot ):
    1) Stop the program
    2) Change or install a new tool enter the offset in the tool table - I use a separate height gauge, not a tool setter, but either would be ok.
    3) reload the program, use 'FIND G30' to get the G30 just before the tool call for the 'changed' tool.
    4) 'Set Start Line' and off you go.
    You have to repeat some machining but usually won't scrap the part and you're not starting all over.
    Would be nice if you could 'Set Start Line' at a safe Z from where you stopped and have coolant state and spindle state resume where you left off. With the above scenario you go back to the last G30 to get coolant and spindle working properly.
  6. #46
    Mar 2013
    Quote Originally Posted by petenc View Post
    Lol... I thought I was the only one that had the shutdown screen text issue. That drove me nuts on day one and it got fixed on day 2. Ill dig it back up on how to change it if anybody else really cares lol.
    Attachment 345360
    I got my Pathpilot in the mail with an update disk a few days ago. I updated it and this screen was fixed to a total different one with the Tormach logo and the message separate. The must have read this thread.
  7. #47
    Nov 2016
    Quote Originally Posted by eltejano View Post
    Woohoo! I am curious to the new shutdown screen, if you get a minute, shoot a pic. Why it really matters I dunno...
  8. #48
    Mar 2013
    Here ya go
    What would you like to be added to the pathpilot software-17036067_10210712167497698_1724271617_o-jpg
  9. #49
    Apr 2011
    Does this mean that there is a V 1.9.9 coming soon? My V 1.9.8 still has the old shut down screen.
    Terry
  10. #50
    Mar 2013
    Quote Originally Posted by MFchief View Post
    Terry
    That is the version I have. The date on the back of my controler box is 02/01/17 so its brand new. May have something to do with it, that it's a newer install.
  11. #51
    Nov 2016
    Terry
    Not impossible, but I would doubt they would change this on a standard .tgp/gpg update. Like eltejano said, itll probably only show up on newer installs.
  12. #52
    Member scott216's Avatar
    Apr 2012
    Quote Originally Posted by rdsi View Post
    We need a tool table import/export function using a something like a comma delimited file format. I realize we can backup/restore a tool table but that format is not really usable by external applications.
    It would be awesome to have the ability to link the tool table to our CAM program.
    Until then, you can use https://konklone.io/json/ to convert JSON to a CSV. I just tried it and it works very well.
    --Scott
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
  13. #53
    May 2011
    Carnation, WA - USA
    I would really like the ability to adjust the tool height offset during a tool change. Sometimes a tool needs adjusting.
  14. #54
    Gold Member MichaelHenry's Avatar
    Jun 2006
    Chicago suburbs
    I would like to see a whole lot more of the filename in the file listings on the left and middle screens.
  15. #55
    Member popspipes's Avatar
    Jun 2014
    Quote Originally Posted by MichaelHenry View Post
    I agree!!
    mike sr
  16. #56
    Mar 2013
    Would be nice to be able to customize the UI, just like different colors and maybe even themes, fonts. I know it makes no difference and it is useless but I like changing things up sometimes.
  17. #57
    Jan 2016
    Since I'm so slow at programming I really could have used a radius cutting feature.
    Dave
  18. #58
    Jun 2006
    Chicago suburbs
    Quote Originally Posted by kevinro View Post
    That would be high on my list, too.
  19. #59
    Nov 2016
    Another vote for a "tall" tool offset for a default. Or an error message/break, or something. I finally got bit yesterday. Managed to save the part and drill, but scared the crap out of me!
  20. #60
    I upgraded my 770 from MACH3 to PATHPILOT about a month ago.
    I finally got around to playing with it yesterday, for a full day.
    Here's a couple of things that bugged me:
    1. When checking a new program, and scrolling thru the lines, PathPilot doesn't "plot" the moves on the display. MACH would display every move, line by line. I used to watch the moves, to know my program was going where it was supposed to go.
    2. The on-screen editor needs some tweaking. I edited a program, renamed the file, saved it, but when I closed the editor, it vanished! It wasn't in my catalog anywhere. I was pissed!! I don't know if I did something wrong, or what. But in MACH, an edited program would automatically be loaded after editing.
    3. Where can I speed up the G00 Rapid move? Parameters somewhere?
    Just a few minor gripes.
    Overall, I think PathPilot is great software. From what I hear, it doesn't have the famous Glitches that MACH has. Yay!!
